Law 2 Evaporated Droplet Model: When particle reach Tvap, then particle temp drop
Old   July 13, 2022, 11:23
Default Law 2 Evaporated Droplet Model: When particle reach Tvap, then particle temp drop
Wut
Wut
Wut is on a distinguished road
Hi
My simulation is the drying process, so i selected droplet particle and enable species transport. In DPM, I use custom law 1 and 2.
Law 1: Heating when Tp < Tvap
Law 2: Vaporization when Tp > Tvap
By drying concept for moisture particle, the Tvap will equal to Twb of hot air. Let say my moisture particle has initial temp 317 K and Twb of hot air is 319 K.
The particle shall be heated up from 317 K to 319 K and after that particle shall have temperature 319 K until end of drying process.
Some paper said this shall use UDF to solve this bug. The below is my UDF code. The key point is I would like to keep particle tempature constant 319 K when using Law2.
#include "udf.h"
#include "dpm.h"
DEFINE_DPM_SWITCH(dpm_switch, p, coupled)
Material *m = P_MATERIAL(p);
if(P_T(p) < DPM_VAPOR_TEMP(p, m))
P_CURRENT_LAW(p) = DPM_LAW_INITIAL_INERT_HEATING;
else
P_CURRENT_LAW(p) = DPM_LAW_VAPORIZATION;
Wut is offline   Reply With Quote
law 2 evap model, particel temp drop
interFoam wave propagation and explosion of Courant number and residuals ChiaraViola OpenFOAM Running, Solving & CFD 1 June 26, 2019 06:36
dispersion model with lagragian particle tracking model for incompressible flows eelcovv OpenFOAM Running, Solving & CFD 54 April 10, 2018 10:36
droplet separation off a particle in turbulent stream anonymous_89 Main CFD Forum 0 August 22, 2013 14:40
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Check particle impaction with User Fortran Julian K. CFX 3 January 12, 2012 10:46
