problem of pressure change with temperature in closed container
Old   July 13, 2022, 01:31
Default problem of pressure change with temperature in closed container
Qinan Li
Lewis Lee is on a distinguished road
I recently used FLUENT to simulate the change of gas pressure with temperature in a confined space. The temperature increase is caused by the combustion of the external gas. The results show that the temperature of the gas in the container has increased significantly, but the pressure is almost unchanged, and the gas density has decreased. I have defined it as an ideal gas in the material, and turned on the compressible option, please tell me how to solve this problem
Lewis Lee is offline   Reply With Quote
chtMultipleRegionFoam: quenching, temperature problem velikaDjoka OpenFOAM 2 March 23, 2021 18:24
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 07:36
the problem that gradually change of temperature contour in coal gasification bluenail FLUENT 0 November 10, 2014 03:41
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
