July 11, 2022, 12:23 |
Torque increase as rpm increase
Muhammad Luthfi
Rep Power: 5 |
Hello, I have done an experiment related to the hydro turbine and I used rope brake dynamometer to measure stall torque by adding a load little by little thus decreasing the rotational speed. I want to validate this result in ansys fluent software by using report -> forces but my torque always increases every time I increase the RPM. How to get the right value of stall torque which is comparable with this experiment result?
Thank you for your help Best regards, Luthfi |
[foam-extend.org] foam-extend-4.1 cannot compile on Centos8 | Ya_Squall2010 | OpenFOAM Installation | 2 | July 22, 2020 02:03 |
[foam-extend.org] paraview not runing? (foam extended 3.2 and ubuntu 15.04) | Milan2013 | OpenFOAM Installation | 23 | April 20, 2017 05:49 |
Install OF 1.6.ext on Arch based distribution | miro2000 | OpenFOAM Installation | 4 | October 9, 2013 14:39 |
OpenFoam 1.6-ext - RPM build errors | preibie | OpenFOAM | 12 | September 8, 2011 03:12 |
Torque & rpm | mAx | FLUENT | 0 | April 12, 2006 07:21 |
