Grid convergence of Fluent
Old   July 11, 2022, 13:22
Default Grid convergence of Fluent
Caserta
fd_flux is on a distinguished road
I'm wondering if Ansys Fluent does simulation on sub-levels of the assigned grid to check the grid convergence. If the answer is no, how do it check for grid convergence? Browsing through the tutorial I didn't find many answers
thanks for the supporting.
fd_flux is offline   Reply With Quote
Old   July 14, 2022, 03:20
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
I think the way for you is grid indepenence test, if I got your question correctly
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   July 14, 2022, 05:47
alainislas's Avatar
Alain Islas
alainislas is on a distinguished road
AFAIK Fluent does not conduct grid independence tests. During the pre-processing you should build your different meshes (coarse, base, fine, etc..) and then, run the simulations. In other words, you need to do this study yourself! Here is an excellent reference on how to perform these tests with the GCI method https://doi.org/10.1115/1.2960953
alainislas is offline   Reply With Quote
ansys fluent 2020r2, ansys fluent 2022 r2
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
Problem with grid convergence for turbulent flow around cylinder aakie OpenFOAM Running, Solving & CFD 3 November 13, 2018 05:39
CFX overwhelming Fluent in mass convergence of boundary layer separation case Pierre1 FLUENT 7 March 26, 2015 22:43
NACA0012 Grid Convergence - nor converging aerospain FLUENT 10 April 21, 2010 13:33
Grid for Fluent v.4 using Gambit? Ray Main CFD Forum 3 October 27, 1999 13:35
