UDF Patching Cells for Secondary Phase source terms |
July 9, 2022, 19:05 |
AnthonyBowers
Rep Power: 6 |
Hi all,
For context, I am simulating a counter flow bubble column. The Liquid will enter through a horizontal side pipe connected to a larger vertical pipe. The secondary phase will be added as a source term, some z-distance. I am using a define-on-demand to patch the source terms. The mass source is M_dot/Patched_volume where M_dot is my input variable. Then as for the momentum source, I have M_dot*Uzb/Patched_volume. My simulation is unstable and diverges on k, epsilon, and vof. I believe the issue is the DOF of my simulation being 2 the mass flow rate and bubble velocity, M_dot and Uzb. So to correct this issue I want to know the cells face area so I can back calculate mass flow rate leaving by bubble velocity as my input variable m=Q*rhob Q=A*vb m=A*vb*rho |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 04:52 |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 09:06 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 17:18 |
SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 11:11 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
