Fractional Step Method failing for propeller simulation |
July 7, 2022, 04:18 |
Varun V P
Rep Power: 6 |
We are studying the effects of oblique flow on variable pitch propellers, and we did wind tunnel experiments for these. Now I am running CFD simulations to study the flowfield.
This is the domain. There is a cuboid of dimensions 2.5 x 2.5 x 2.5 m, within which I have 2 cylindrical halves for each blade. Within them I have another cylinder which actually encloses the blade. The middle and the inner domain have a conformal mesh. I did this so that I can quickly rotate the inner section to simulate different pitches. The strategy I was following is to first run the steady state simulation for 500 iterations, with the transition-SST solver (other transition solvers are crashing) and SIMPLE coupling, and then switch to NITA FSM for transient because it's faster, and I assumed that the solution will be unsteady at higher oblique angles. While this strategy worked for the no-wind simulations (CFD results close to experimental,) I am getting divergence in the continuity equations when I give a velocity input of 10 m/s. This happens in the transient part, static is able to converge well till 1e-3 for continuity. On observing the velocity contours I observe spurious sections with very high speeds, near the inlet (>200 m/s). Some sections of the mesh could do with some refinement, so I enabled automatic adaption for volume change and mass imbalance, every 10 iterations. I also reduced the under relaxation parameter to 0.1 for the momentum eq. I am still observing divergence. I ran the simulations with a more refined mesh, but I am still observing the same issues. As a stopgap solution I am now running the simulations with SIMPLE pressure coupling because it works, though it takes a lot of time. But I still want to know why this problem is happening. Could it be because the compressibility condition is not able to be satisfied, acc to this (Monitoring residuals , is it safe ? |
continuity error, fractional step method, nita, transient analysis, velocity |
Numerical implementation of Boundary conditions in fractional step method | jollage | Main CFD Forum | 13 | November 16, 2021 10:48 |
Rhie-Chow interpolation in Fractional Step Method | AliE | Main CFD Forum | 5 | December 10, 2018 09:16 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 11:08 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
