DPM model in closed system?
Old   July 6, 2022, 14:37
Default DPM model in closed system?
dawid.kruczek is on a distinguished road
Hello! Is it possible to create a dpm model without inlet and outlet? I'm interested in introducing particles into the fluid that is under the cone. The entire simulation takes place in a closed cylinder-cone system. Image in attachment.
dawid.kruczek is offline   Reply With Quote
Old   July 8, 2022, 05:02
alainislas's Avatar
Alain Islas
alainislas is on a distinguished road
Yes, I see 2 ways of achieving this.
(1) The injection file. For that you’ll need to specify parameters such as
(( x y z u v w diameter temperature parcel-mass mass n-in-parcel time flow-time) name)
in a raw ascii file. You can control the injection by start-time and stop-time.
(2) Alternatively, if during the pre-processing you prepare a mesh that distinguishes a fluid region where the parcels are to be injected. You can later use an “artificial” surface injection selecting the proper int_fluid region. Then, the parcels will “sprout” from the face centres of such region.
alainislas is offline   Reply With Quote
ansys, dpm, fluent
New Phase Compressible Turbulence Model for multiphase system vishal3 OpenFOAM Programming & Development 0 November 24, 2015 01:17
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
DPM + Eulerian Model Shane FLUENT 2 July 14, 2004 09:26
question of DPM model Cindy Jones FLUENT 8 November 18, 2002 22:58
