July 6, 2022, 11:21 |
Pressure did not match!
Rep Power: 4 |
Hi all,
I applied a known pressure drop (pressure inlet and outlet) to get an idea of the leak velocity through the membrane. Then I tried to set the same average leak velocity and inlet velocity with the same pressure outlet. When I looked at the static pressure contour, I found the static inlet pressure was two times larger than before. Does anyone know where the problem is? I tried changing the inlet pressure for the first case and putting new velocities for the second case, and the same thing happens! Thank you. |
Simple Box - Gravity with Pressure Outlet - Unrealistic Reverse Flow | pyccknn | FLUENT | 2 | December 1, 2021 17:31 |
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions | Vishnu_bharathi | CFX | 12 | November 21, 2017 06:56 |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
UDF in Fluent to Match Mass Flow at Pressure Outlet | Jonas Larsson | Main CFD Forum | 1 | April 29, 1999 10:44 |
