Perforated wall model repost error:Received signal SIG |
Jeremiah Goldwald
Rep Power: 0 ![]() |
I am trying to use perforated wall model to simulate gas entering the fluid zone through holes. When I use Eulerian modelsand then set the perforated wall model, the iteration could not continue, and the initialization also report same error.
Node 7:Process 8812:Received signal SIGSEGV ===================================== 999999:mpt_accept:error:accept failed:No such file or directory 999999:mpt_accept:error:accept failed:No such file or directory 999999:mpt_accept:error:accept failed:No such file or directory 999999:mpt_accept:error:accept failed:No such file or directory 999999:mpt_accept:error:accept failed:No such file or directory 999999:mpt_accept:error:accept failed:No such file or directory The fl process could not be started. The same error occurred when I did it under Linux hpc. Is it that perforated wall model cannot be used in multiphase flows? Last edited by jeremiah1994; July 6, 2022 at 03:09. |
multiphase flow, perforated wall |
Model of air–steam flow with condensation into the volume and surface wall | gartz89 | Fluent UDF and Scheme Programming | 0 | February 9, 2022 23:26 |
Divergence in AMG solver! | marina | FLUENT | 20 | August 1, 2020 11:30 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 18:19 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
