Transient Chart will not plot in the CFD-Post |
July 4, 2022, 20:50 |
Thai Pham
Rep Power: 4 |
After completing the calculation, I needed to get the velocity with respect to time data as well as pressure from the fluent simulation. All of this is performed in CFD-Post. For some reason though, the chart shows up blank when I try to create the transient plot. I started out making a point that I would get data from. It is a 2D simulation so my XYZ are 0.06, 0.005, 0 and I made the domain "all domains." I went to create a chart and pressed "XY - Transient or Sequence" in the General Tab and changed the location to the point in the Data Series Tab. When I pressed Apply, the axes titles showed up but no plot.
I tried changing the values of the point to node number to see if maybe the point wasn't on the 2D body, but nothing showed up with various nodes. Also the contour of the velocity and the pressure shows up when I created it. I was also able to create a line location and was able to get "XY - Line" data out of it so I know that the data from the calculation came over correctly. Based on what I have seen online, I should be doing this correctly. If anyone has had this issue in the past and knows how to resolve it, your help would be greatly appreciated. Here is a list of conditions that I put on the simulation if that could be an issue. Solver: Transient, Pressure Based Number of Time Steps: 600 Time Step Size: 1 Max Iterations/Time Steps: 20 Laminar Flow Fluid material: Water-Liquid Method: Simple Initialization: Hybrid Mesh cell size: 0.0005m Nodes: 260053 Elements: 258440 Boundary Conditions: Inlet velocity = 0.115 m/s Wall = No Slip Outlet Gauge Pressure = 0 Pa |
July 9, 2022, 00:08 |
Thai Pham
Rep Power: 4 |
Bump. Perhaps its because I am on the student edition?
General recommendations for CFD hardware [WIP] | flotus1 | Hardware | 19 | June 23, 2024 19:02 |
Lift distribution chart in CFD post | Techies | Main CFD Forum | 1 | April 9, 2022 01:39 |
Chart animation CFD post | alinik | CFX | 1 | November 16, 2017 17:25 |
plot the graph by using cfd post data | subhas.hunasikatti@gmail. | ANSA | 0 | October 24, 2013 02:55 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 22:10 |
