July 4, 2022, 07:38 |
Flame ignition not ocurring
Luis Porto
Rep Power: 4 |
Hello everyone.
I am currently simulating a methane air combustion using the jones and lindsted mechanism and using the thermodynamic and transport data from the grimech mechanism. It is a premixed combustion using the eddy dissipation concept model. The problem is, I am getting no ignition even after patching the inlets to a high temperature. I guess the problem is not with the simulation itself because when the temperature of the inlet is high the reaction occurs. Any suggestions to solve this problem? Case: -Pressure-based solver -Realizable k-e model -do for radiation -Species Model with EDC model - Air and Ch4 enter at the same inlet in 3D model at 300K - Inlets are mass-flow and outlet is outflow I have tried patching the entire furnace for 2000K or even just a part of the inlet but nothing happened. Should I give initial values for the quantity of products I am predicting to obtain? Thank you very much. |
January 4, 2024, 14:01 |
Rep Power: 3 |
Hello. Have you solved this issue? Could you share you Jones and Lindstedt mech file?
Thanks |
combustion, ignition |
Ignition and flame propagation with XiFoam for a few meters long comput. domains | Gloq | OpenFOAM Running, Solving & CFD | 1 | February 21, 2023 13:22 |
Simulation of the Sydney Bluff Body Flame ignition | Hogi | Main CFD Forum | 0 | December 9, 2015 10:28 |
Premixed flame ignition energy | Londo | Main CFD Forum | 0 | July 13, 2015 11:57 |
how to use setFields for flame ignition?? | Dan1788 | OpenFOAM Running, Solving & CFD | 5 | September 25, 2014 21:26 |
How to model a heat source for ignition of flame | harshad88 | FLUENT | 3 | November 21, 2013 02:18 |
