Adjoint Solver Method Pressure Drop Calculation |
June 30, 2022, 11:46 |
Rep Power: 6 |
I want to define a pressure drop observable in the ANSYS FLUENT Andjoint Solver Method. The problem is, that my "outlet" where I want to measure the total pressure loss in comparison to the inlet (which is defined as a boundary layer) is not defined as a boundary layer (in fact it is a nozzle exit). I tried to import a .stl surface but that didn't work as the Adjoint Solver apparently only accepts boundaries as input. Is there a workaround for this issue? Thanks |
July 5, 2022, 11:25 |
Rep Power: 6 |
Anyone has experience with this problem?
July 5, 2022, 11:54 |
Void_CFD-user
Rep Power: 4 |
July 5, 2022, 12:00 |
Rep Power: 6 |
I don't mean boundary layer, that was wrong by me. I am refering to a boundary surface which only acts as an exit plane/area for post processing the information at the exit of my nozzle (which is placed inside a bigger domain possessing inlet and outlet bc). The thing is - without this interior surface I can only look at the desired flow information at the nozzle exit plane/surface in post processing. But I need the solver (Fluent) to access this area during calculation by having access to the interior surface.
I hope it is clear now. If not I will try to get a picture for you. Thanks |
July 5, 2022, 12:07 |
#5 | |
Void_CFD-user
Rep Power: 4 |
If you are looking at adjoint solver, you are probably trying to optimse your nozzle. In this case you can split your simulation for inside the nozzle and outside. That's the only way you can use adjoint for the nozzle. |
July 5, 2022, 12:15 |
Rep Power: 6 |
Almost, the physical outlet of the nozzle has no boundary condition at all, yet.
The nozzle itself has a boundary inlet condition, no exit condition (the exit condition is defined by the nozzle pressure ratio etc.). The nozzle exit flow enters the rest of the cylindrical domain. This domain consists of pressure ff bc and a pressure outlet bc (those do not interfere with the physical outlet of the nozzle). I want to introduce the interior surface to the physical nozzle exit to be able to process the information stored at the nodes at that location (that way I can for example monitor the total pressure loss along the nozzle and other important design parameters). Yes, you are right. I am trying to optimize the geometry of my nozzle with the Adjoint solver. Could you please elaborate on splitting my domain on for inside the nozzle and outside? I think thats actually that what could be the best solution. |
July 6, 2022, 04:37 |
#7 | |
Void_CFD-user
Rep Power: 4 |
adjoint solver, fluent, optimization parallel |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
Kvs calculation - Pressure drop | Geo573 | ANSYS | 0 | February 24, 2021 04:20 |
help in pressure drop calculation in fluent | sinaupdate | FLUENT | 3 | July 10, 2016 05:56 |
Pressure Drop calculation | shubham208011 | FLUENT | 10 | March 30, 2016 14:15 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
