June 28, 2022, 20:55 |
Calculate the total melting time
International
Hello all,
I am running a transient melting/solification simulation, and I want to define the total melting time as an output parameter. For this I tried two different solutions, but none of them is working fo me. 1/ The first one is to define a stop criterion to interrupt the solution once the liquid fraction reaches the value of 1, and the total melting time would be the flowing time. For this one I tried the following scheme command in the execute command: (if (< 0.1 (pick-a-real "/rep/area/average 2 , liquid-fraction n")) (cx-interrupt) When I run the simulation I get this error "Error: eof inside list / Error Object: ()" 2/ The second solution I tried is defining an expression with the IF statement as follows : IF(AreaAve(LiquidFraction,['interior-pcm'])==1,{flow-time},1[s]) The problem with the IF statement is that it is necessary to define a value when the condition is not satisfied, while in my case I only want it to take the value of the flow time, otherwise I want it to keep its initial value. I hope it was clear and not too long, and I really appreciate if anyone can help me in any of those methods. Many thanks, Seldon |
ansys fluent, melting/solidification, total melting time |
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 42 | May 7, 2024 23:17 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 05:49 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
