Convergence issue with DPM method
Old   June 14, 2022, 23:38
Default Convergence issue with DPM method
Arijit Saha
ari003 is on a distinguished road
Hello everyone,
Hope you all are doing good. I need an assist related to convergence issue with Discrete Phase Method simulation. The solver I am using is K-epsilon Realizable with enhanced wall treatment, algorithm as Coupled with momentum, TKE , TDR as first order discretization, Pressure and gradient as second order and Least square cell method respectively. With all the relaxation factor as default (even with low relaxation factor) I am getting oscillatory residuals especially for the case of continuity residual ( I ve attached a pic below). Since, I am new to this DPM simulation and willing to ameliorate my knowledge further, I hope to get some advice on how to minimize this oscillation in the residuals as in my knowledge it is really undesirable. Please let me know if any further details are required about the problem.
Also, the simulation is steady, min orthogonal quality is 0.18.
ari003 is offline   Reply With Quote
Old   September 22, 2024, 15:38
The protagonist is on a distinguished road
I am having a similar problem. My residuals also oscillate for larger flow rates (8e^-2) but the solution converges nicely for lower flow rates (8e^-16). Were you able to resolve your problem? If yes, then how?
I would greatly appreciate it.
Thanks
The protagonist is offline   Reply With Quote
VOF, DPM model - particle penetrate phase interface issue! dwoh12 Fluent Multiphase 1 May 20, 2022 00:49
Density Sensitive Convergence Issue Jojell OpenFOAM Running, Solving & CFD 0 March 16, 2022 07:23
convergence and off wall spacing issue josip76 FLUENT 0 June 4, 2011 19:13
how to ensure convergence for DPM Soubhik FLUENT 1 February 11, 2007 17:55
convergence acceleration by preconditioning method Atit Koonsrisuk Main CFD Forum 4 June 5, 2000 07:21
