June 2, 2022, 14:31 |
Flame temperature too low
Luis Porto
Rep Power: 4 |
Hello everyone.
I am currently trying to simulate a combustion of methane in a furnace with 4 inlets. Each inlet enters at a flow rate of 0.078 kg/s and the air and ch4 enter simultaniously. The mass fraction of ch4 is 0.33 and the mass fraction of o2 is 0.154 entering at 300K. I am getting the flame formed properly (I think) but the temperature is too low (800K) while I should be getting values close to 2000K. What might be wrong? I have tried to increase the temperature of the inlets but nothing changed. I am using a polynomial function for cp, thermal conducitivity and viscosity. Any help would be aprecciated. I have attached an image of a plane representing two of the inlets and the residuals. Thank you |
April 11, 2023, 00:45 |
combustion model
Gopal Pandey
Rep Power: 3 |
what combustion modelling approach did you used? EDC, EDM, Premixed, Non-Premixed? And also, which turbulence model did you adopted?
combustion, fluent |
Static Temperature / Opening Temperature | JulianP | CFX | 12 | April 10, 2019 19:00 |
strange extreme low radiation heat flux on fixed Temperature surface | fxzf | OpenFOAM Running, Solving & CFD | 0 | March 7, 2018 17:09 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 18:00 |
Too low Flame temp for Spe.Tran. Produce Gas Comb | Manoj Prasad | FLUENT | 4 | November 22, 2005 02:09 |
Flame temperature | newbie | Main CFD Forum | 0 | June 14, 2002 03:38 |
