May 24, 2022, 11:18 |
mass flow inlet ramp divergence
Giuseppe
Rep Power: 6 |
Hi to everybody!
I'm simulating hydrogen injection during the compression stroke insinde an internal combustion engine chamber. The injector is just a simple cylinder with constant area. At its inlet I'm imposing a mass flow inlet condition because I have the experimental data of it. The profile is trapezoidal: a ramp-up from 0 to the target mass flow in 1 crank angle, then a constant mass flow for 15 crank angles and after a ramp down of 1 crank angle. I'm sure the hydrogen flow is choked throughout the injection. In the mass flow inlet window, I tried to impose only the mass flow profile, but after a few time-steps during the ramp-up the simulation diverged (fluent adviced me that the it was limiting the inlet mach number to 0.98). For this reason, under the hypothesis of choked flow, I have tried to give in the mass flow inlet window also the static pressure profile corresponding to mach = 1. It worked for the ramp-up and the steady state, but anyway the static pressure during the ramp up wasn't the one I assigned in the static pressure profile. Now I'm having troubles with the ramp-down, fluent does some time-steps correctly, then it starts diverging (also setting a static pressure profile corresponding to the choked condition) and from what I have seen, it calculates a completly non-sense total pressure when it starts diverging. Any suggestions to solve this issue? |
mass flow inlet, ramp |
Calculate Mass Flowrate and Mass Flow Averaged Total Pressure at inlet and outlet | coolcrasher | OpenFOAM Post-Processing | 7 | November 4, 2021 04:57 |
Mass flow rate history over solution step- rhoSimpleFoam | gian93 | OpenFOAM Post-Processing | 0 | December 8, 2019 10:20 |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
How to define a fixed velocity for a given mass flow rate on inlet | mqasimali | FLUENT | 2 | April 12, 2013 17:24 |
