Non-uniform heat flux UDF boundary condition around a cylinder
Old   May 24, 2022, 11:20
Default Non-uniform heat flux UDF boundary condition around a cylinder
Celine Lim
climshwuling is on a distinguished road
Hello all,
I have been trying to write a heat flux UDF around a cylindrical tube to be applied as a boundary condition in Fluent, and I have been running into some issues regarding defining the "circumferential" direction of the cylinder tube for it to properly represent the heat flux around the tube.
The heat flux I have obtained is through the SolTrace software for concentrating solar collectors. SolTrace outputs a plot for the non-uniform heat flux distribution along the circumference (x-axis) with respect to heat flux (y-axis) of a cylindrical receiver tube. My plan was to write a UDF code that plots a polynomial function of the non-uniform heat flux with respect to circumference of the cylindrical receiver tube, however, i've been running into a lot of errors as I am not sure how Fluent defines a circumference in this case. Is it by angle? Is it by Arc Length? It seems like my error occurred due to not having a good understanding on how Fluent measures/defines circumferential geometries for writing UDF.
If anyone has any experience defining a heat flux UDF profile with respect to a circumferential tube, I would appreciate it if you have any insights on how I should write my UDF code to properly represent the non-uniform heat flux distribution around the tube in Fluent. Of if anyone can help with clarifying how Fluent measures/defines circumferential geometries for writing UDF that will be very helpful too!
Thank you,
climshwuling is offline   Reply With Quote
cylindrical heat flux, fluent, non-uniform heat flux, udf
Neumann boundary condition for heat flux using UDF Yadu krishnan Fluent UDF and Scheme Programming 6 September 14, 2021 08:53
Simulating constant heat flux value at solid-solid boundary Y27 STAR-CCM+ 6 September 8, 2020 10:56
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
