Is pressure-based solver adequate for a transient simulation ?
Old   May 23, 2022, 23:28
Default Is pressure-based solver adequate for a transient simulation ?
y t b
y__tb is on a distinguished road
Hi guys, I need some advice on an adequate solver setting to simulate transient flow.
I’m trying to simulate a high-pressure pneumatic valve flow for 2 seconds, which is quite short.
The overall flow speed would not become over Mach 3.
Since some geometries are moving, a dynamic mesh would also be necessary.
Would there be any standard for setting a solver and schemes?
I’m trying to use a pressure-based solver and standard k-e turb model with a small time-step (1e-6 ~ 1e-7). Max iter would be a default, 20.
But, I’m concerned about using a pressure-based solver, which is implicit, when simulating such shot time transient simulation.
Any advice? Thanks for all.
y__tb is offline   Reply With Quote
Old   May 24, 2022, 00:15
Lucky
The smaller the time-step, the more it makes sense to use a pressure-based solver over a density-based one. I've also used a pressure-based solver for Mach numbers greater than 5 and found no issues. I don't have any advice except to tell you that the pressure based solver works for transient problems.
Pressure based and Density based Solver Xobile Main CFD Forum 39 August 19, 2020 07:04
Wrong fluctuation of pressure in transient simulation caitao OpenFOAM Running, Solving & CFD 2 March 5, 2015 22:33
the role of speed of sound in pressure based solver 759599290 Main CFD Forum 0 March 3, 2014 03:39
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 08:25
pressure based solver fadhil FLUENT 2 May 28, 2008 07:29
