May 23, 2022, 07:44 |
Particle track wrong value colormap
Rep Power: 8 |
Hi all,
I'm currently displaying a particle track of a user value (P_USER_REAL in the UDF) but the colormap of the display gets wrong values if I don't have "Auto Range" on. In the attached images you can see the problem, in the one with the colormap from 0 to 5.95 I used autorange and in the one that has only negative values I didn't. That's the only difference between the images, I didn't change the min max values calculated from auto range. Is there a way to correct this issue? I'm using fluent 17 on windows. |
particle color, particle track, udf, user variable |
Import Particle Track in CFD-Post | ap.ahmad7238 | FLUENT | 0 | February 8, 2019 10:04 |
import particle track in CFD-Post | ap.ahmad7238 | CFX | 1 | February 8, 2019 09:50 |
Particle size and Mesh Size; Particle tracking; | Suman Sapkota | CFX | 11 | August 12, 2018 19:39 |
Particle Track in CFX | Jmac | CFX | 14 | July 13, 2017 10:58 |
Track after particle hit the wall. | Brigido | CFX | 9 | October 28, 2013 13:33 |
