Repeated error message for Fluent meshing when trying to enclose fluid regions
Old   May 22, 2022, 12:44
Default Repeated error message for Fluent meshing when trying to enclose fluid regions
thehungrygraduate is on a distinguished road
I have received this error multiple times during the described geometry workflow step in fluent meshing:
Error: A cap could not be created using the specified zone/label. Ensure your zone/label encloses the whole opening.
Error Object: #f
I have gone back into Spaceclaim to fix holes and inexact edges until I pass the geometry check. However, this has not fixed the problem. Are there any general steps I should take or is this type of error only relative to the geometry I am using? In other words, are there any easy fixes?
thehungrygraduate is offline   Reply With Quote
Old   September 13, 2022, 05:15
Pradyumna
Pradyuman0007 is on a distinguished road
Error Object: #f
Were you able to solve the error? I am having the same problem and I'm new to Ansys. Help regarding the error will be greatly appreciated.
Pradyuman0007 is offline   Reply With Quote
Old   January 23, 2023, 15:35
Apoorv Mishra
Mishra Apoorv is on a distinguished road
did you get the answer or found the problem? Can you help me out with the same?
Mishra Apoorv is offline   Reply With Quote
error #f, geometry fluent, meshing 3d
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points Simurgh OpenFOAM Meshing & Mesh Conversion 4 August 25, 2023 08:58
Problem with isolated fluid Regions zacko CFX 2 February 8, 2017 03:34
isolated fluid regions were found alfin CFX 14 October 8, 2015 02:36
Fluid Regions donot communicate via "Attach" Boundaries sdwijeya STAR-CD 0 August 28, 2009 14:26
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
