Initializtion gives me ZERO values
Old   May 11, 2022, 07:36
Default Initializtion gives me ZERO values
mohammad
mohammad is on a distinguished road
Hello everyone,
I am simulating a centrifugal fan (air) and when my inlet is "Mass Flow Inlet", the Initialization always gives me ZEROS and I can't start my simulation. Do you have any suggestions?
Best regards,
mohammad is offline   Reply With Quote
Old   May 11, 2022, 14:22
Void_CFD-user
Indra is on a distinguished road
Originally Posted by mohammad View Post
Hello everyone,
Best regards,
What initialisation are you using. Try standard with compute from inlet and double check the values.
If you want better initialisation, try FMG(but you wouldn't need it tbh)
Indra is offline   Reply With Quote
Old   May 11, 2022, 17:22
Default It was my mistake
mohammad
Hi everyone.
It has been my mistake and FLUENT was ok
The problem was that Mass Flow Rate accepts XYZ direction. And in my case, the direction was wrong (tangent of the inlet). Hence, the initialization values were all zero.
initialize, mass flow inlet, zero values
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 23:38
Velocity values are normal but pressure values are too big rv82 OpenFOAM Running, Solving & CFD 4 April 13, 2015 04:59
Setting patch field values equal to internal field values leroyv OpenFOAM Programming & Development 1 October 21, 2014 16:49
Plotting raw data values Wilesco Siemens 0 January 5, 2006 06:34
