April 30, 2022, 04:47 |
periodic boundary condition
Elmahdy
Rep Power: 4 |
Hello everyone,
I have made a pipe with a periodic boundary condition (translational) and when I define a mass flow rate, everything goes fine and I can get the pressure drop. However, I have a problem where I want to define a pressure gradient this time and get the mass flow rate as an output. The mass flow rate box gets de-activated, I cannot initialize the problem from the periodic boundary, the convergence is too slow, and finally I cannot get the mass flow rate unless I go to the reports and get the number, which turned out to be away lower than the expected and totally wrong. Does anyone have an idea why this happens? |
April 30, 2022, 21:07 |
Lucky
Rep Power: 66 |
You should be retrieving mass flow rate from a report. You shouldn't be initializing from a periodic boundary, use standard initialization and and directly give the fields. The convergence is not any slower, it's just your initialization is off. All working as intended.
May 1, 2022, 05:12 |
#3 | |
Elmahdy
Rep Power: 4 |
May 1, 2022, 17:34 |
Lucky
Rep Power: 66 |
You seem to be under the impression that they are somehow different. The archetype of the periodic BC is the pressure gradient. The mass flow option is the same BC using a pressure gradient, but Fluent iterates the pressure gradient until the set massflowrate is achieved. If it can be done with massflow rate, then it can definitely be done using the pressure gradient approach. If it doesn't work with a pressure gradient then it definitely won't work with the massflow option.
May 2, 2022, 02:58 |
#5 | |
Elmahdy
Rep Power: 4 |
November 27, 2024, 14:17 |
#6 | |
Anurag
Rep Power: 3 |
I am trying to model two phase air water flow using VoF in fluent in a pipe and am using the periodic BC. There is no option to specify the mass flow rate, it is deactivated. So, shall i initialise normally from Initialization and keep the pressure gradient option (inside the periodic settings) as it is? Thanks AB. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Turbomachinery Mass imbalance | sheaker | CFX | 12 | September 5, 2019 09:09 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 05:39 |
Unsteady Periodic Boundary Condition | EMolina | SU2 | 0 | July 24, 2014 17:16 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
