Periodic boundary condition on coil flow
Old   April 25, 2022, 06:32
Default Periodic boundary condition on coil flow
Vestdam
Vestdam is on a distinguished road
Hi there,
I have encountered a problem when simulating flow through a coil. The coil is quite long and to reduce computational power I would like to simply model one coil revolution and apply periodic boundary conditions with a specified mass flow rate.
This approach works fine for a straight tube or pipe, but with a coil, where the flow direction is not parallel to the translation vector, I can not get a proper solution. The fluid is water and I am using k-w SST with the coupled solver.
Under boundary conditions -> periodic conditions I specify the mass flow and flow direction. With the flow direction parallel to the actual direction of the flow, the resulting velocity field is not as expected (checked by simulating multiple revolutions). With the flow direction parallel to the translation vector, the model gives me an error and stops.
I hope there is a way around this behavior.
Thanks in advance.
Vestdam is offline   Reply With Quote
Old   May 10, 2022, 03:17
Vestdam
According to ANSYS support, it is not possible to use the periodic boundary condition for this type of geometry.
Old   May 10, 2022, 04:01
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
thank you for sharing,
which approach did you finally used to simulate this case?
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   May 10, 2022, 05:44
Vestdam
At this point I have to simulate more coil revolutions, export the outlet velocity profile, translate the geometry and apply the profile at the inlet.
I am investigating whether this approach is possible with an UDF though.
Constant mass flow rate boundary condition sahm OpenFOAM 0 June 20, 2018 23:45
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Multiphase flow with Periodic Boundary Condition luludonotcry Fluent Multiphase 1 March 16, 2016 06:51
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
