MHD problem simulating AC current
Old   April 19, 2022, 13:26
Default MHD problem simulating AC current
Jad Diab
jdiab is on a distinguished road
Dear all,
I am working on the modeling of an AC plasma arc.
Using the MHD module, I am trying to simulate an AC electric current on an electrode surface, but am not able to add a function/expression on the current or voltage in the MHD module boundary conditions to simulate the AC current through a sinusoidal function/expression.
The MHD module apparently only takes constant values for voltage or current as boundary condition.
When adding the function/expression in the fluent's general boundary conditions, the MHD module does not read them either.
Is there a way to add a function/expression for the voltage or current in the MHD module?
If not, is there a way to simulate an AC current on a certain surface in fluent with the MHD module ON?
Thank you for your help,
Jad.
jdiab is offline   Reply With Quote
Old   April 24, 2022, 12:25
Default same issue
Salah Gaffar
salahgaffar is on a distinguished road
Have you found a solution yet to this issue? because I am facing the exact same problem and I cannot find the answer anywhere.
salahgaffar is offline   Reply With Quote
Old   August 1, 2022, 09:39
sina
sina_sls is on a distinguished road
Originally Posted by jdiab View Post
Dear all,
Jad.
Hello
I want to set sinusoidal value of electric potential (MHD module) for a wall, first i try expression but i faced to error :
Error: wta(2nd) to string_eq
Error Object: __expr__
then i try Profile and UDF profile , but agian i faced to problem , when i use them it consider the wall to insulated.
Could you help me how can i set sinusoidal value for current density ( Electric Potential MHD) ?
Best Regards,
sina_sls is offline   Reply With Quote
fluent, mhd
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 08:48
A problem in simulating free decay of ship hanyuanzhao CFD Freelancers 1 April 11, 2017 05:30
Problem simulating katabatic winds Arcannys Main CFD Forum 0 January 25, 2017 18:18
Problem in simulating turbine blade with periodic BC scl641 FLUENT 1 January 18, 2011 19:23
Plz help. Urgent! MHD problem Rucy FLUENT 0 May 25, 2007 07:35
