Calculating surface area
Old   April 11, 2022, 09:34
Default Calculating surface area
Jim Bakker
JiBa93 is on a distinguished road
Hi all,
For my internship i want to determine the minimal surface area of a tracheal stenosis. The 3D mesh is produced from a segmentation of a CT scan, as seen in the attached files.
i want to determine the surface area in the smalest part of the mesh, where the stenosis ocures. the problem is that the centerline of the mesh is not aligned with the x-, y- or z- axis. I've been looking for several days now on youtube and different fora, but i can not find the answer to my question or a solution to a comparable problem.
Can anyone explain to my how i can determine the surface area perpendicular to the centerline which runs from the center of the inlet to the center of the outlet.
many thanks in advance.
JiBa93 is offline   Reply With Quote
Area weighted average over slice of surface spelletier FLUENT 0 June 13, 2019 23:53
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
Calculating forces on a non-closed surface ScottN FLUENT 0 March 1, 2011 18:18
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
