Gas particle flow through shock tube incorporated with diaphragm |
April 9, 2022, 00:25 |
Ayushman
Rep Power: 4 |
Hi All!
My problem is " Gas particle flow through shock tube which has driver and driven sections and these sections are separated by Diaphragm. A solid particle is placed just at the diaphragm and gas flows from the driver to the driven section along with the solid particle. I could not track the particle and the pressure varies from -ve to +ve in my simulation result. My pressure in the driver section is 0.9MPa and my pressure in the driven section is atmospheric pressure. Gas is air. The velocity of the particle is 0.5 m/s. I have no gas velocities value. |
track the particle. |
Adding helium gas into shock tube driver section | spkumar | OpenFOAM Running, Solving & CFD | 1 | December 7, 2021 23:55 |
Lagrangian particle tracking in periodic flow | jabeken | STAR-CCM+ | 2 | April 11, 2021 10:07 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
Modelling Shock Tube with Venting | RCBlast | Main CFD Forum | 1 | December 17, 2012 09:40 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
