Duplicated case leads to different results
Old   April 8, 2022, 12:12
Default Duplicated case leads to different results
Leoma is on a distinguished road
Hello!
I am currently simulating some basic flows to learn fluent and the following strange problem occured.
I have created a case, duplicated it and solved both of them. The results from both cases are identical as they should be.
Now I initialised both cases again and ran them once more (with same settings). But now the results differ from each other and I dont know why.
Do you know where the problem might be?
Update: I initalised both cases for the third time and run them again and now the results are identical again. Now I'm beyond confused.
Leoma is offline   Reply With Quote
different results, initialising
Rising Bubble Test Case Using interFoam: Unrealistic Results?! farazarbabi OpenFOAM Running, Solving & CFD 21 May 7, 2021 09:45
Crazy results on a simple case, no turbulence decay stardust23 OpenFOAM Running, Solving & CFD 3 March 26, 2020 06:18
how to map results from steady state run to tranient case? phsieh2005 OpenFOAM Running, Solving & CFD 2 November 7, 2010 07:20
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 17:31
Test Case results for Semi-Cylinder shankar1221989 Main CFD Forum 0 June 24, 2009 07:35
