April 3, 2022, 18:59 |
Non-uniform volumetric heat flux generation
São Paulo
My problem comprises a heat transfer between a porous medium and a fluid in which it is submerged.
The problem is that the porous medium has non-uniform volumetric heat flux (W/m3) generation. Do you know how to set a heat generation profile in the porous medium in the Ansys Fluent? Could I use the profile input tool or it would require a UDF? |
April 4, 2022, 00:08 |
Lucky
Rep Power: 66 |
The volumetric profile is just a text table. It's basically a .csv table. If you can generate such a table it can definitely work. Anything can be done in a UDF, it's a UDF.
April 5, 2022, 17:11 |
São Paulo
Thank you for the answer Tran!
I will try to implement a heat generation profile based on Ansys manual. Let’s see if it works. |
generation, heat flux, media, non-uniform, porous |
Measure of Heat Flux on a surface | MathieuCrslt | FLUENT | 0 | October 10, 2018 06:58 |
Inlet patch problems | martyn88 | OpenFOAM Running, Solving & CFD | 6 | April 21, 2017 19:34 |
simpleFoam Floating point error (Core Dumped) | sam.ho | OpenFOAM Running, Solving & CFD | 2 | December 31, 2013 07:57 |
OpenFOAM solution is diverging for stress analysis in two-pahse microstructure. | Sargam05 | OpenFOAM | 16 | April 30, 2013 17:18 |
Difference between Total Heat Source and Volumetric Heat Generation? | sieginc. | STAR-CCM+ | 1 | March 26, 2013 04:20 |
