Can I use wall functions for calculating drag of a supersonic aircraft?
Old   March 31, 2022, 10:21
Smile Can I use wall functions for calculating drag of a supersonic aircraft?
CellZone is on a distinguished road
as the title already says: I am trying to simulate an aircraft flying supersonic (mach 1.8 ) in high altitude : since the geometry is quite complex, I get a lot of bad cells when I use prism layers.
In order to avoid to go down to y+=1 and having lots of cells I am wondering if I can use wall functions of the k w sst model by trying to achieve y+>30 ?
Will this give me an accurate solution regarding the calculation of the drag? The shock system will have a fine resolution in order to capture the effects.
Thank you for your feedback
Best regards
CellZone
CellZone is offline   Reply With Quote
How to solve the boundary layer without wall functions? WhiteW OpenFOAM Running, Solving & CFD 4 January 20, 2020 05:55
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 16:33
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Wall functions in SU2 xgarnaud SU2 3 March 6, 2017 15:50
How are Wall Functions Practically Implemented! pche8701 Main CFD Forum 2 June 2, 2016 11:58
