March 26, 2022, 07:05 |
Reference Values from Input Parameters
Adam
Rep Power: 5 |
Hi all
I know Cl and cd etc are essentially calculated using the 'reference values' section of fluent. In my problem I am modelling a wing that rotates with the mesh (to simulate AOA changes) and want a changing x velocity inlet as a input parameter. I want this to range from 20-40ms I was wondering if it was possible to use this input parameter as the reference value? If not, what value should I use for the reference values section in order to obtain good results across the range of speeds? Just the average i.e 30ms? Perhaps a UDF? Many Thanks! |
fluent, input parameters, reference values |
Using a function of input parameters as reference value | mich_K | FLUENT | 1 | March 26, 2022 07:06 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 06:37 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
Error in compiling new drag model | k.farnagh | OpenFOAM Programming & Development | 13 | May 21, 2016 04:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 01:34 |
