I do CFD
Rep Power: 4 ![]() |
I'm doing a simulation of steady, incompressible flow using the default values of Fluent's solver settings for turbulence and solver (SST K-Omega, coupled). In the domain of interest I have the following boundary conditions: 1- Velocity Inlet 2- Pressure Outlet 3- Pressure Inlet 4- Mass Flow Inlet 5- Mass Flow outlet (same value as point 4) considering a good resultion mesh, I am having problems with convergence. Basically the solution doesn´t converge! ![]() Is there something wrong with my BCs? Stability Issue? ![]() |
fluent, hvac |
Annulus Flow Through Multiple Inlets and Outlets, Fluent (Student) | Mecha | FLUENT | 1 | July 9, 2021 03:19 |
boudary condition for 2 inlets 2 outlets | salomama | OpenFOAM | 2 | August 17, 2018 12:48 |
OpenFOAM - Multiple inlets / outlets | C. Okubo | OpenFOAM | 0 | April 26, 2018 17:51 |
50 inlets / /50 outlets? | Steffen595 | CFX | 10 | May 18, 2016 01:44 |
Prevent a phase to leave from a certain outlet among multiple outlets | abc197 | Fluent Multiphase | 7 | February 3, 2016 20:18 |
