No Convergence in Channel With Jet Impingement |
Christian
Rep Power: 4 ![]() |
Hi there,
I am running a simulation of a channel with a mainstream flow, intercepted by a flow of a high velocity jet at an angle. The jet impinges onto a heated surface, then both flows exit at the end of the channel. I am having a hard time getting Fluent to converge to 10e-6, with residuals converging to about 5e-4 and then oscillating about that value/ I have heard that oscillation could be due to inadequate inflation layers, so I increased the number of inflation layer elements on all surfaces, but I am still getting no convergence after many hours. Can anyone suggest any fixes? The working fluid is air, modeled as an ideal gas, k-epsilon turbulence model, gravity enabled, and the SIMPLEC method (Coupled method does not come close). Mainstream velocity is 10m/s (Re = 19,000; Ma = 0.03) and temperature is 303.15K. Jet velocity is 50m/s (Re = 49,000; Ma = 0.14) and temperature is 303.15K. Jet intercepts main flow at 45 degree inclination. Channel exit is given the "outlet vent" boundary condition. A picture of the failed residuals is attached. |
I do CFD
why donīt you use pressure outlet rather than outlet vent?
Outlet vent boundary conditions are used to model an outlet vent with a specified loss coefficient. |
#3 | |
I do CFD
also it may be the mesh resolution problem. 1e-6 convergence may need very fine mesh
Lorenzo Galieti
Rep Power: 12 ![]() |
If anything, finer mesh hampers convergence, doesn't improve it xD.
Can we see the flow field? Maybe it's just that it doesn't find a steady state solution... Can sometimes be possible. I would anyways stick to the coupled method. |
convergence, fluent, residuals |
Grid Convergence Study in Cold Plasma Jet | Mourousias | Main CFD Forum | 2 | July 9, 2016 14:14 |
Jet Impingement | Sabayonetta | FLUENT | 0 | February 27, 2016 02:57 |
Jet impingement on granular surface | ocea | FLUENT | 3 | February 3, 2015 02:29 |
Convergence of jet flow simulation | MiraLisa | FLUENT | 0 | August 15, 2013 04:44 |
free Jet Channel | Martinsk | FLUENT | 0 | August 7, 2009 02:08 |
