huge values of velocity and force for hydrofoil |
March 7, 2022, 11:48 |
mohammad
Rep Power: 5 |
Hi
I'm trying to simulate a floating hydrofoil in water by 6DOF solver in fluent (time transient). hydrofoil is NACA 0012 and chord length is 1m and span length is 1.5m. I insert the hydrofoil in the center of a cubic domain. Velocity inlet is 1m/s and gravity is -9.81 m/s2. The hydrofoil mass is 216kg and I calculate moment of inertia. I set these properties in 6dof properties. The velocity and force of hydrofoil increase every time step when the values are so huge fluent give "floating point exception" error. When I change fluid from water to air it seems ok. The force of the hydrofoil and mesh is shown below. Thanks [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
6dof |
huge values of velocity and force for hydrofoil | mmd96 | FLUENT | 0 | March 5, 2022 17:41 |
Import .csv - velocity profile - error | eSKa | CFX | 9 | April 3, 2021 14:38 |
Drag Force Ratio for Flat Plate | Rob Wilk | Main CFD Forum | 40 | May 10, 2020 05:47 |
serial udf to parallel udf | radioss | Fluent UDF and Scheme Programming | 10 | January 19, 2019 09:56 |
SixDoFRigidBodyMotion under OF2.3 ( self oscillating cylinder) | Scabbard | OpenFOAM Running, Solving & CFD | 1 | July 22, 2014 05:50 |
