Metal foam meshing in fluent
Old   March 1, 2022, 16:35
Default Metal foam meshing in fluent
Chaitanya
nandacd is on a distinguished road
Hello
I am currently working on the simulation of metal foams. I am using fluent meshing and have done surface meshing and the skewness was 0.7. But during volume meshing I am getting an error. The associated message is the following "Error: Unresolved gaps have been detected at the indicated locations. To resolve these gaps, either close the gaps using share topology or refine the mesh at the gaps."
I tried to use share topology but according to spaceclaim there is no coincident topology in the model neither contacts in the model when I use share topology and forced share respectively. Also, when i use the check geometry feature or the gaps command the geometry seems watertight no matter how small the tolerance gets.
Anyhelp in this regrad will be highly appreciated
nandacd is offline   Reply With Quote
Old   March 3, 2022, 06:48
Void_CFD-user
Indra is on a distinguished road
Originally Posted by nandacd View Post
Hello
There's a lot of things that can be wrong here. Try reducing the size during surface meshing and maybe there'll be a size at which it works.
If it is a very complex geometry which large dimensions and small gaps, try simulating a smaller model first, that'll reduce the length scale and make meshing easier and you'll be able to see if there's any errors in your geometry.
You can also try to increase facing quality in spaceclaim. This might help capture the geomteyr features better, btw fluent meshing laso has the capability to improve faceting.
Indra is offline   Reply With Quote
unresolved gaps
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 23:50
