Preserve meshes in Fluent parametric run
Old   February 28, 2022, 12:53
Question Preserve meshes in Fluent parametric run
Harry W
hwerner2014 is on a distinguished road
Good morning Fluent users,
I'm working on a parameterized case in ANSYS Fluent where I am manipulating geometry using parameters to test several different configurations of a two-airfoil system. The parameterization works great, however I would like to just generate the meshes for each case once, retain the mesh data, and then run all further calculations on the existing mesh for each case. I should note that the meshes are static meshes, not dynamic. Once generated, the nodes do not change position.
At this point, the geometry parameters are now constant and I just want to run a few different flow conditions, turbulence models, and numerical schemes while keeping the meshes consistent between runs. Is there any way to make Fluent retain all the old meshes and just update the solutions so I can do some grid-independent analysis between configurations and compare the performance of different models and flow conditions? Or, if I am generating unstructured meshes, will the meshes generate the same every time? (I don't think so, but my understanding of meshing algorithms is poor).
hwerner2014 is offline   Reply With Quote
Old   February 28, 2022, 13:40
Lucky
This is a question for workbench and how to set up a job in workbench because Fluent doesn't even mesh.
In Fluent: is it possible? Absolutely. What do you have to do? Literally nothing (as far as Fluent is concerned). Fluent reads in a mesh and then uses all the settings, blah blah blah. Yes I am aware there is such a thing as Fluent Mesher, but that technically isn't Fluent either. Regardless, the answer is the same.
People do calculations on a fixed grid all the time.
Old   February 28, 2022, 17:29
Lorenzo Galieti
LoGaL is on a distinguished road
I believe, if you save the mesh file, then read it with the fluent block, without connecting the mesher block at all, (basically your workbench file only contains the fluent block), it shouldn't try to mesh it again
LoGaL is offline   Reply With Quote
fluent, meshing, parametric
[TUTORIAL] Run fluent on distributed memory with 2 windows 7 64 bit machines ghost82 FLUENT 54 February 9, 2022 04:32
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench aarvay ANSYS Meshing & Geometry 11 January 12, 2017 13:51
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Parallel run in fluent for multiphase flow apurv FLUENT 2 August 3, 2011 20:44
resume and run fluent for another timestep via a c greg FLUENT 2 June 30, 2005 06:01
