Constant Speed Submarine 3D Dynamic Mesh - Fluent |
cmunikat
Rep Power: 0 ![]() |
* Lets say that I am trying to simulate a simplified submarine, 3D. * It travels at constant speed. * The submarine movement is controlled by UDF, no explicit propulsion is simulated. *ERROR MESSATE: NEGATIVE CELL VOLUME DETECTED * I COULD PROPERLY SIMULATE THIS ON FLUENT 2D, BUT TRIED EVERYTHING AND ALWAYS FAILS ON 3D SIMULATION. * I tried using smaller time step, layering, smoothing and remeshing combinations. Always the problem above. * COULD YOU PLEASE SUGGEST HOW TO SET UP THIS MODEL? THANKS |
Marcin
Rep Power: 10 ![]() |
Is this a rigid body?
If so, maybe try the overset mesh, instead of dynamic mesh, which is very error-prone. |
dynamic mesh, fluent 3d, negative cell volume |
6DOF Dynamic mesh for a floating rigid body in fluent v20 | Tushar Patel | Fluent Multiphase | 0 | September 22, 2021 06:02 |
Trouble modelling a 2D gear pump simulation using dynamic mesh in Ansys Fluent 19 | vivjk94 | Main CFD Forum | 0 | September 20, 2021 00:25 |
FLUENT 6DOF dynamic mesh error pressure | huhanghui | FLUENT | 0 | September 20, 2017 07:16 |
Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh | Emanuele88 | FLUENT | 0 | February 9, 2016 11:39 |
Dynamic mesh + apaption in Fluent 12 ? | klunker | FLUENT | 0 | September 23, 2009 08:19 |
