Rodrigo Villarreal
Rep Power: 9 ![]() |
Hi, I'm making a calculation involving species transport and I tried to first establish the flow field and then turn on the species transport option WITHOUT solving simultaneously the fluid flow equations for each phase (3), but it seems that by doing this the species contours doesn't show turbulent diffusion behavior. Is there a way to include the turbulent diffusion and only solve the species transport equation?
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Just for clarification, you have the option to check/uncheck the species equations yes?
You can freeze the flow solution and still get the turbulent species transport term. You can also freeze the flow and turbulence solvers. You just need the species transport solver still selected. |
Rodrigo Villarreal
Thanks for your answer. Yes, I have the option of species transport on, but the contours show the same pattern of the velocity vectors. I'll try to freeze/unfreeze the flow equations to see if it changes.
species transport model, turbulence |
Fixed Bed Gasifier, Species Transport Problem | therandomestname | FLUENT | 12 | January 4, 2019 07:08 |
Direct numerical simulation of species transport equation with phase change | Pmaroul | Main CFD Forum | 2 | October 12, 2018 16:02 |
Mixing tank, MF-VOF and Species Transport - Divergence Error | soheil_r7 | Fluent Multiphase | 0 | September 11, 2018 05:29 |
species transport, two species with water prop's in micro channel, Solution Divergin | manoj.dundi | FLUENT | 0 | May 25, 2016 10:07 |
Questions for a species transport problems (snapshots attached) | aleisia | FLUENT | 2 | October 9, 2011 04:40 |
