Why am I getting negative torque at high tip speed ratio? |
Good Guy
Rep Power: 0 ![]() |
Hello, Good day.
I'm simulating a wind turbine, I designed on my own, using ANSYS FLUENT. At tip speed ratio equal to 5 and lower, I'm getting positive torque. However, at tip speed ratio equal to 6 and above, I'm getting negative torque. Since I have frame motion enabled, the wind turbine is "still spinning in the correct direction" from looking at the vortex visualization by q-criterion, but if this was in the real world, I think, negative torque would mean that the wind turbine is spinning in the opposite direction. I made an airfoil pressure cut plot and from the looks of it, it seems normal. Is my simulation incorrect or does this simply just mean that the design is bad? If the latter, what would be a good explanation of this? I apologize for posting twice. I thought the previous one was not posted. Last edited by Good Guy; February 14, 2022 at 03:32. Reason: posted twice |
wind turbine |
high rotational speed centrifugal pump | marekpl | CFX | 43 | April 25, 2022 18:41 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Grid deformation for high aspect ratio grids | praveen | SU2 Shape Design | 5 | February 15, 2013 19:50 |
MUSCL shock capturing on high aspect ratio meshes | vijay_paul | Main CFD Forum | 1 | September 29, 2012 00:16 |
