Contra-rotating moving mesh zones
Old   February 9, 2022, 23:36
Default Contra-rotating moving mesh zones
Nathan CHEN
Saintree is on a distinguished road
Hi all,
I am simulating a pair of contra-rotating propeller using single-passage domain.
First I did the calculation using steady pressure-based coupled solver with moving reference frame (MRF) and mixing plane interface. Then I switched it to transient case and changed to moving mesh zones, but this time the calculation broke immediately and Fluent said this:
Node 1: Process 9092: Received signal SIGSEGV.
No matter I tried the interface with periodic repeats, pitch change, or no pitch change types, there was just no change, i.e., still breaking immediately.
It seems that Fluent does not allow two mesh motion zones together. If I tried one moving mesh zone and one MRF zone, things would go well and the calculation could proceed.
Does anyone know the reason for this and how to solve it? Any help from you would be highy appreciated.
Many thanks,
Nathan
Saintree is offline   Reply With Quote
contra-rotating propeller, mesh motion, moving mesh, sliding mesh
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Rotating Cylinder (Moving wall vs Moving reference frame vs Sliding mesh) hamed.majeed FLUENT 2 January 17, 2017 13:18
Moving Wall, MRF or Sliding Mesh for modelling rotating rim and tyre? Field85 FLUENT 3 March 18, 2016 11:09
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 07:54
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
