February 6, 2022, 10:18 |
Trouble importing mesh from GMSH
#1 | |
Arijit Saha
Rep Power: 7 |
Hello everyone, hope you all are doing fine. I need some help regarding a problem I am facing. I wished to import a 2D mesh from GMSH(.msh file format) and run the simulation in Fluent. But when I try to edit in the setup section it runs into an error and which is follows:
P.S- I am using Ansys Fluent 19.2 release. |
February 7, 2022, 04:38 |
Alexander
Rep Power: 34 |
run fluent in standalone mode, choose 2D solver
best regards ****************************** press LIKE if this message was helpful |
February 7, 2022, 04:50 |
#3 | |
Arijit Saha
Rep Power: 7 |
Thank you for your response. I ran in standalone mode and then tried to read the mesh file (.msh) but still encountering this problem:-
Mesh Changing When Importing from Fluent | russel60 | OpenFOAM Running, Solving & CFD | 0 | February 15, 2019 17:43 |
[Gmsh] GMSH : structured mesh issue | bibiboom | OpenFOAM Meshing & Mesh Conversion | 0 | May 17, 2017 19:49 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[Gmsh] background mesh in gmsh | Nick_J | OpenFOAM Meshing & Mesh Conversion | 1 | March 20, 2013 05:20 |
[Other] Importing 3D mesh from ANSYS to OpenFOAM | martyn88 | OpenFOAM Meshing & Mesh Conversion | 0 | September 3, 2012 20:12 |
