Coefficient of pressure problem
Old   February 5, 2022, 08:37
Default Coefficient of pressure problem
G
Ghs007 is on a distinguished road
I'm modeling the wind load on a house caused by high velocity wind 30 m/s +. I'm trying to get the coefficient of pressure on the roof but the values are in th range of 2 to -6. That range isn't correct as it doesn't match with experimental data. What can I possibly be doing wrong.
I already set the reference velocity/pressure value to the value at the outlet.
Ghs007 is offline   Reply With Quote
coefficient of pressure, fluent, wind loading
viscosity udf don't use correct temperature and strain rate rezvani Fluent UDF and Scheme Programming 8 May 27, 2021 06:40
Problem with an old Simulation FrankW CFX 3 February 8, 2016 05:28
high CPU load with no computation going on & Pressure coefficient output problem spetsnaz26 FLUENT 0 September 30, 2011 06:25
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
