Creating Animation in HPC Cluster Run
Old   February 3, 2022, 01:40
Default Creating Animation in HPC Cluster Run
Can Unsal
Battousai07 is on a distinguished road
Hello All,
I am running my case on HPC with journal file. I am trying to create an animation.
1) When i create my animations on GUI, they are not recognized in batch mode and no animation is saved.
2)I try to add the following command to my journal file
==> /solve/animate/objects/create animation-1 scene-1 10 view-1
but probably this is not the right way to write this command.
My scene, and my views are already created.
Does anybody know the right way to making selections for solve/animate/objects/create command?
Note: I tried the display method that doesn't work as well and what works for me is this solve/animate command.
Thanks in advance.
Battousai07 is offline   Reply With Quote
Old   February 4, 2022, 02:44
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
type in console
solve animate objects create
press enter you will see the list of available options
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
HPC Cluster Configuration Question chuckb Hardware 1 September 8, 2018 09:26
Cluster 2 server units to run star with mpi? RCB0B STAR-CCM+ 1 August 16, 2017 21:05
[OpenFOAM.org] OF_2.3.0 in HPC cluster with paths modified aerospain OpenFOAM Installation 1 May 13, 2015 11:02
on the run flow-rate evaluation on a cluster wstapel OpenFOAM Programming & Development 3 August 26, 2014 15:55
Microsoft HPC cluster for CFD - question Rory - Administrator Main CFD Forum 8 November 13, 2006 13:59
