Formula 1 Car Front Wing High Residual Analysis |
January 25, 2022, 13:21 |
Metin
Rep Power: 5 |
I'm simulating a multi-element F1 car front wing in ground effect. I'm using velocity inlet, pressure outlet, symmetry for top and side planes and finally a moving ground as boundary conditions. I managed to have validated results for certain ground clearances and my residuals were around 1e-4. I wanted to decrease the ground clearance and since I decreased the ground clearance, the velocity gradients under the wing increased a lot and this made it an unsteady analysis. When I try to run this simulation as unsteady, the residuals decrease but it would take so long to get a meaningful result from it. When I try to run this simulation as steady, the residuals are about 1e+0 which is too high. I already did some local grid refinements and face sizing refinements too but I wasn't able to solve the issue. Do you have any ideas about how to solve this problem? Best Regards, Metin |
February 2, 2022, 21:19 |
Alexander
Rep Power: 34 |
you may try to make better quality mesh
best regards ****************************** press LIKE if this message was helpful |
front wing, ground effect, residuals fluent |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 14:47 |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 13:50 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 06:49 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 19:17 |
