heat flux in coupled wall
Old   January 17, 2022, 11:44
Default heat flux in coupled wall
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Hello all,
I am defining a common wall between two fluid annuls of a circular cylindrical pipe. the wall obviously splits into wall and shadow. So, I have a problem in defining heat flux. Basically, I need to apply heat flux in this common shared wall. The problem is that when coupled wall is defined, I cannot select heat flux (defined by UDF). If I select heat flux, the temperature is extermely high 9000K.
Regards,
SJ
Shamoon Jamshed is offline   Reply With Quote
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
User Wall Heat Flux Dyls STAR-CCM+ 0 May 13, 2013 12:58
