January 12, 2022, 12:52 |
viscous model for flow over complex body
mody
Rep Power: 5 |
hello, I have a complex body which I want to see the pressure drop over it.
when I try to mesh fluid with tetrahedral. My max skewness is .81 without inflation. can I come up with good results without inflation? which viscous model would I use then ? Then when I used inflation it went up to 94.5 Is it acceptable for max skewness? which viscous model should I use then? Capture.JPG |
boundary layer, fluent, turblance problem, viscous model, yplus |
Ahmed Body Validation Study – Autodesk CFD | Nik CFD | Autodesk Simulation CFD | 3 | February 12, 2021 05:29 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 17, 2020 00:44 |
Flow over a blunt body - SST turbulence model | bharath | CFX | 5 | January 29, 2016 11:16 |
about Subgrid-scale model | impecca | OpenFOAM Running, Solving & CFD | 4 | December 20, 2013 11:36 |
different viscous model in particular zones | Jiri Novak | FLUENT | 1 | July 22, 2005 12:00 |
