Ansys crashes when running UDF related to moisture content
Old   January 12, 2022, 09:34
Default Ansys crashes when running UDF related to moisture content
louis
louis123 is on a distinguished road
We are currently using Ansys student version 19. We can compile and hook the UDF to Ansys but when we try to Initialize or run the calculation the Ansys set up crashes the error states that:
999999 mpt_accept ; error: accept failed: no error
The f1 process could not be started
We got this UDF code from a research paper: "The application of computational fluid dynamics codes to simulate heat and moisture transfer in stored grains"
#include "udf.h"
#define ACP 921.69
#define BCP 18.077
#define CCP 112.35
#define RHOB 639.2
#define PATM 101325
#define TMEAN 288.15
#define TAMP 5
int last_ts = -1;
DEFINE_INIT(initial_humidity, d)
real W, Tabs, TC, r, psat, p, w;
Thread *t;
cell_t c;
thread_loop_c (t, d)
begin_c_loop(c,t)
C_UDMI(c,t,0) = 0.1364;
W = C_UDMI(c,t,0);
Tabs = C_T(c,t);
TC = Tabs-273.15;
r = exp(-ACP/(TC+CCP)*exp(-BCP*W));
if(r>0.99)
{r = 0.99;}
psat = 6.0e25/pow(Tabs,5) *exp(-6800/Tabs);
p = r*psat;
w = 0.622*p/(PATM-p);
C_UDSI(c,t,0) = w;
end_c_loop(c,t);
DEFINE_SOURCE(mass_source,c,t,dS,eqn)
real Tabs, TC, W, w, pe, re, drebydpe, We, Source_w, psat,drying_constant;
Tabs = C_T(c,t);
TC = Tabs-273.15;
W = C_UDMI(c,t,0);
w = C_UDSI(c,t,0);
pe = w*PATM/(0.622+w);
re = pe/psat;
We = -1/BCP*log(-(TC+CCP)/ACP*log(re));
drying_constant = 2000*exp(-5094/Tabs);
C_UDMI(c,t,3) = re;
C_UDMI(c,t,2) = We;
C_UDMI(c,t,1) = -RHOB*drying_constant*(W-We);
Source_w = -C_UDMI(c,t,1);
dS[eqn] = 0.0;
return Source_w;
DEFINE_ADJUST(update_mc,d)
real Tabs,TC,physical_dt,W, We, w, pe, re,Wnew,psat;
cell_t c;
Thread *t;
int curr_ts;
curr_ts = N_TIME;
if (last_ts != curr_ts)
last_ts = curr_ts;
printf ("ADJUST: iteration = %d , ==== \n", curr_ts);
physical_dt = RP_Get_Real("physical-time-step");
thread_loop_c(t,d)
begin_c_loop(c,t)
Tabs = C_T(c,t);
TC = Tabs-273.15;
W = C_UDMI(c,t,0);
w = C_UDSI(c,t,0);
re = pe/psat;
Wnew = W+C_UDMI(c,t,1)*physical_dt/RHOB;
W = Wnew;
C_UDMI(c,t,0) = W;
end_c_loop(c,t)
DEFINE_SOURCE(hygro_source,c,t,dS,eqn)
real Tabs, TC, w, psat, dpsatdt, drdt, hsbyhv, hs;
real pe, re, We, we, dwsebydt, Source_t;
Tabs = C_T(c,t);
TC = Tabs-273.15;
we = C_UDSI(c,t,0);
pe = we*PATM/(0.622+we);
re = pe/psat;
dpsatdt = psat/Tabs*(-5+6800/Tabs);
drdt = ACP*re/pow((TC+CCP),2)*exp(-BCP*We);
hsbyhv = 1+psat/re*1/dpsatdt*drdt;
hs = hsbyhv*(2501.33-2.363*TC)*1.0e3;
C_UDMI(c,t,4) = hs;
Source_t = C_UDMI(c,t,1)*hs;
dS[eqn] = 0.0;
return Source_t;
louis123 is offline   Reply With Quote
Old   January 13, 2022, 00:21
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
changes which are not related to your problem:
change physical_dt = RP_Get_Real("physical-time-step");
to
physical_dt = CURRENT_TIMESTEP;
printf to Message0
code must be compiled
did you allocate 5 user defined memory locations and 1 user defined scalar in Fluent GUI?
as the code is complicated I recommend to test your case with very simple UDF to check if everything is correct in your case settings:
#include "udf.h"
return 0.01;
return 0.01;
0.01 is just a random value, you do better put something reasonable here.
if this simple code works well, add some parts of code and check if they work
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
ansys 19, crashing, udf and programming
Error in UDF calling parameters from ANSYS WorkBench anand32 Fluent UDF and Scheme Programming 0 April 6, 2018 20:52
A CFX-POST error (ver 14.5.7) wangyflp88 CFX 2 July 22, 2017 01:17
ANSYS Licensing Problem, Processes Running but Showing as Not Running penguinman ANSYS 3 September 27, 2016 14:30
2-way FSI in Ansys CFX 15 LucasGasparino CFX 3 August 6, 2015 04:17
Problem related with UDF for dynamic mesh Ryan FLUENT 6 April 29, 2004 10:29
