December 28, 2021, 06:37 |
Centrifugal Fan - Left handed faces
ClemensK
Rep Power: 5 |
I did a frozen rotor simulation of a centrifugal fan in CFX, which worked pretty fine (impeller meshed with turbogrid). But afterwards I noticed that CFX doesn't support the eulerian wall film model, which is what I need in further investigations. So I changed to Fluent und the problems began... I imported the CFX case in fluent. When I define the interface between the impeller and the volute Fluent says that there are overlapping zones and left handed faces are present. I have already tried all commands to fix these left handed cells. The solution diverges after a view interations, because (I think so) Fluent cannot handle these cells well. I also tried to set up a new case without dependecies to CFX (impeller meshed with ansys mesher) but there the same problem appears. What I looked up: The diameters of impeller and volute are the same for sure. Additionally the allignment of the rotation axis is the same. I do not know how to continue. Anybody has an idea? |
cfx, fluent, frozen rotor, left-handed faces, mfr |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 10:23 |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 19:32 |
[snappyHexMesh] [checkMesh] Highly skew faces detected after snappyHexMesh during checkMesh | Vignesh Veeresparan | OpenFOAM Meshing & Mesh Conversion | 1 | March 9, 2020 00:24 |
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) | AndreP | STAR-CCM+ | 10 | August 2, 2018 08:48 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 10:01 |
