How to get certain complex graph plots in Ansys fluent? |
December 16, 2021, 09:24 |
AMDB007
Rep Power: 5 |
I am fairly new to using Ansys fluent. I am simulating combustion and I want to compare my results with a paper that I am referring. I have easily obtained the contour images and also some simple graph plots like static pressure & temperature within Fluent itself. In that paper (where they also used Ansys) they have plotted graphs for Combustion Efficiency%, and Total Pressure Loss%. I was wondering if I can make those kind of graph plots in Ansys for my comparison as well. If it is possible can someone kindly give me guidance as to how to acquire them, since I was not able to find it in fluent under the XY Plot feature. I am happy to give additional info if required. I am attaching the images of those plots in that paper. Thank you |
December 16, 2021, 13:03 |
Lucky
Rep Power: 66 |
It's a pain in some parts of your body to do this in Fluent. Do it using excel, tecplot, matlab, gnuplot, etc.
December 17, 2021, 13:45 |
AMDB007
Rep Power: 5 |
Oh, thanks.
But how do I extract the solution data specifically for those two parameters? I couldn't find them when I tried to export the sol data. |
December 17, 2021, 15:26 |
Lucky
Rep Power: 66 |
These are all post-processed quantities. They don't just jump out at you on the screen like pressure, velocity, temperature, etc.
Get the definitions from whatever literature you are reading. Total pressure loss is more-or-less self-explanatory. Both both of these are going to be some types of surfaces averages/integrals (and sometimes mass-flow weighted averages) that you get from reports. Then you get the report out of Fluent and into your plotting tool. |
December 18, 2021, 10:38 |
#5 | |
AMDB007
Rep Power: 5 |
Thank you. I now understand that I have to first define such specific quantities that are little complex so that Ansys will calculate and generate a report for me which I can use to plot those graphs. Unlike ordinary parameters such as pressure, temperature, etc. that are readily available. And I was able to see the 'Report definitions' option under which I saw some of the things that you have mentioned above. |
cfd - post, fluent, graph result, post procesing, result comparision |
GPU acceleration in Ansys Fluent | flotus1 | Hardware | 63 | May 12, 2023 03:48 |
Building a "home workstation" for ANSYS Fluent | Ep.Cygni | Hardware | 25 | November 11, 2020 03:11 |
drag coefficient in ansys fluent 12.0 | krishna | FLUENT | 19 | April 12, 2018 01:49 |
Using ANSYS Fluent 18.0 on workstations with multiple network cards and PBS Pro | cheezum | Hardware | 0 | February 28, 2017 11:23 |
Can you help me with a problem in ansys static structural solver? | sourabh.porwal | Structural Mechanics | 0 | March 27, 2016 18:07 |
