UDF measuring transient DPM concertation when airflow is steady. |
November 29, 2021, 15:37 |
Jake C
Rep Power: 6 |
I am running a one-way coupled DPM simulation with a very large number of massless particles from an instantaneous release in the context of indoor air quality.
I would like to use a steady-state airflow field, but would like to get the transient particle concentrations in each cell at a time-step that is much larger than the individual particle time-steps. The only way i found for exporting particle data when using steady-state airflow was by using: Results>Graphics> Particle Tracks > and selecting "step by step" >report to file This results in an extremely large .dpmrpt file with the trajectory of each particle at every particle time step. I don't have much experience with UDFs, but all the discussions I have seen using UDFs to get the transient particle concentrations appear to use unsteady-particle-tracking and are then called at each flow time step. Is there a way to call a similar function at a specified time increment not related to the particle time steps? Can anyone give me more advice on post processing one-way coupled steady-airflow simulations with transient particle releases? |
dpm, one-way coupled, steady state dpm |
Will the results of steady state solver and transient solver be same? | carye | OpenFOAM Running, Solving & CFD | 9 | December 28, 2019 05:21 |
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. | Ari | Fluent UDF and Scheme Programming | 4 | May 31, 2016 08:51 |
Steady/ Transient Calculations | Saidul | ANSYS | 0 | May 4, 2015 22:04 |
Steady/ Transient Calculations | Saidul | ANSYS | 0 | May 4, 2015 19:15 |
Difference between steady and transient problems | Jianping Zhang | Main CFD Forum | 9 | April 14, 2003 06:17 |
