Generating thrust from a momentum source in Ansys Fluent in a ducted fan
Old   November 25, 2021, 05:33
Exclamation Generating thrust from a momentum source in Ansys Fluent in a ducted fan
Chiara
Chiara1618 is on a distinguished road
Good morning,
I'm trying to simulate the thrust generated by a propeller in a ducted fan in Ansys Fluent. For the propose I've introduced an actuator disk inside the ducted fan and inside this disk I've put a momentum source (N/m^3).
My question is now: how can I calculate the thrust generated by the fan? And how is this related to the momentum source imposed?
Thanks
Chiara1618 is offline   Reply With Quote
Old   November 25, 2021, 22:42
jsm
JSM
jsm is on a distinguished road
How propeller and fan are connected? What is actuator disk? Your question is not easy to understand.
Without seeing the geometry, difficult to answer your question. Please add some images of geometry.
With regards,
JSM
jsm is offline   Reply With Quote
Old   November 26, 2021, 03:47
Lucky
The volumetric momentum source (in N/m^3) integrated over the disk region is the thrust (in N). Since you impose the momentum source and decide the shape of the disk, it's just simple algebraic multiplication of the source strength and volume of the disk.
Old   December 1, 2021, 04:45
Chiara
The propeller is inside the ducted fan. Instead simulate the complex propeller I've inserted a disk in the domain (actuator disk... It's just a fluid region with no boundaries) within which I've put a momentum source
Old   December 1, 2021, 04:47
Chiara
Ok so supposing I insert a momentum source of 1000N/m^3 in a disk of volume 0.1m^3, I should expect a thrust of 100N... How do I prove I obtain this thrust??
Old   December 1, 2021, 19:28
Chris
cbooks77 is on a distinguished road
If you are trying to get detailed results for thrust then why would you make such a big assumption to the geometry? Model the Fan blades explicitly using the MRF approach. Then integrate the forces on the blades to calculate the thrust. The MRF is not even very expensive to run.
cbooks77 is offline   Reply With Quote
Old   December 2, 2021, 02:35
Chiara
My final geometry is too complex to simulate also the fan. I need to proceed this way but knowing the thrust which is generated by this model
Old   July 10, 2024, 11:04
S Satish Kumar
satishorion is on a distinguished road
Were you able to solve the thrust issue. I am also trying to do the same ducted propeller but its a complete 360 Deg model with the duct. The direct result output from the fluent for normal force on blade and the momentum approach are giving different thrust values.
Regards
Satish
Originally Posted by Chiara1618 View Post
Good morning,
Thanks
satishorion is offline   Reply With Quote
actuator disk, ducted fan, momentum source, propeller, thrust
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 06:18
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
Doxygen documentation Tanay OpenFOAM Installation 9 September 23, 2011 12:40
